Message 1 of 3
router
hi
currently have the bt home hub 2. appears to be slow. we are supposed to have 70mbs speeds. have done a speed test and bt are saying its fine from the exchange to the router.  Would changing the router make the downloads speeds faster as I try and download games via steam and max downloads speed is 10mbps.
it all confuses me :S
2 REPLIES 2
Message 2 of 3
Re: router
BT quoted speeds are connecting speed to your hub not download speeds.
Are the steam download speed in bits or Bytes remembering there are 8 bits in a Byte  so sped of about 70 Mbits will give download about 8MBytes
Are you using ethernet or wife remembering WiFi suffers from interference which will reduce download speed
Message 3 of 3
Re: router
Are you sure you are not getting MBps and Mbps mixed up.
One thing that often gives people confusion is the difference between a (MB) Megabyte (used for file size) and a (Mb) Megabit (used for download speeds). People often assume that a download speed of 1 Megabit per second (1 Mbps) will allow them to download a 1 Megabyte file in one second. This is not the case, a Megabit is 1/8 as big as a Megabyte, meaning that to download a 1MB file in 1 second you would need a connection of 8Mbps.
This would mean if you were mixing them up you would be downloading a 10MB file at approx 80Mbps which would be in line with your estimated speeds.
