Message 1 of 5
sky TV keeps dropping connection
All other WiFi works all the time
I reset it, 5 minutes or sooner it drops out again,  been fine for years
It will show connected a minute later disconnected
Turned it on and off,  and router cnx then drops again but only for the tv
Any help much appreciated
4 REPLIES 4
Message 2 of 5
Re: sky TV keeps dropping connection
I must add, the WiFi works fine using my firestick on the same fibre and tv
Message 3 of 5
Hi @Gtfc and thanks for posting.
Can you give us more detail on your set up? How are things connected? Wireless or wired? Are you using adaptors?
Cheers
David
Message 4 of 5
BT Fibre Broadband
Sky TV is via normal Sat
The cnx is Wifi, don't have a long enough lead to wire it, I know The wifi must be fine because I can run everything (Firestick) off it, even though SKY says no connection.
I can reset the cnx and it's fine, 2 mins later it's fine, then loses it again. So right now looks ok, scroll to home and it's gone again.
I'm no expert so i switch HDMI for the stick and once again that's fine, totally baffled, unless it's the box
Message 5 of 5
Sorry no idea what you mean by adaptors
