Message 11 of 15
Re: BT SPORTS UPGRADE
Odd. Could you please reboot the box (turn the power off and on again) - this should force it to pick up the subscription again.
Message 12 of 15
TNT sports shown in The Guide but when he presses on say 408 he gets code IPC6001
Message 13 of 15
Ok will do asap
Message 14 of 15
Yes, I’ve got TNT sport channels thank you. Is there anything particular I need to tell the person when I reorder?
Message 15 of 15
OK great.
No - just follow the same process that you did previously. If it fails again then I'll get a specialist to call you back and do it manually.
