Message 1 of 3
BTTV IPC6007
Hi, I have 2 BTTV boxes all has been fine until one of the boxes had a hard drive failure - it has been replaced by BT. Now I get an IPC6007 error saying I have too many boxes connected when I try to watch a sport channel on the original box or use the BT TV app ( I am billed correctly for both) any suggestions please.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: BTTV IPC6007
If I remember correctly, this is just the system reacting to seeing a third box attached to the line, as the maximum currently is 2 and it doesn't know one of your boxes will never reconnect (because it is broken).
Usually, you can click on "set up" or similar wording and confirm that this new box is now the main (or master) box and you should be able to continue. You may need to also do this the next time you use the other box, then the system knows these are the 2 boxes in use going forward.
Message 3 of 3
Re: BTTV IPC6007
Thank you for your help, this is now working correctly, many thanks.
