Message 1 of 10
Bt pro box
Does the bt pro box have a I r receiver to use the older non Bluetooth remote
Tags (1)
9 REPLIES 9
Anonymous
Not applicable
Message 2 of 10
Re: Bt pro box
Yes.
Message 3 of 10
Re: Bt pro box
Finally an answer
bt said no
many thanks
so it will def work with the older non Bluetooth tooth remote,
I need 2 remotes for same box and also need an I r type remote to get to work with BroadLink/Alexa voice remote.
Tags (1)
Message 4 of 10
Re: Bt pro box
Yes. Definitely. I use a combination of old and new remotes with my box (one at each end of the sofa - yes, I'm that lazy).
Message 5 of 10
Re: Bt pro box
Us too
so your using a Bluetooth and an I r type remote on the newest shape bt pro box?
cheers
Tags (1)
Message 6 of 10
Re: Bt pro box
Correct. All remotes for any model of YouView box will work with the BT TV Pro Box.
Message 7 of 10
Re: Bt pro box
Many thanks again
shame BT’s experts didn’t know that😁
Message 8 of 10
Re: Bt pro box
Atleast the one on here does.😁
Message 9 of 10
Re: Bt pro box
Thanks for help with previous question regarding the pro box remote
I also can’t find voice command settings in my box’s settings for using with alexa?
I’m guessing some box’s don’t come with it?
Cheers
Anonymous
Not applicable
Message 10 of 10
Re: Bt pro box
Neither voice search or Alexa integration are available on the Pro Box.
