Message 11 of 15
Re: Can't purchase Fury v Whyte
Select BT TV from the apps menu, or press the purple button on your remote that says BT Player on it.
Message 12 of 15
See I don’t have a button that says bt player on my remote. My box and remote are from 2015 and they say “youview”. There’s nothing that says bt player and I’ve never needed to access the apps. It’s probably there buried deep in a menu somewhere but it’s not in an obvious place.
I’m not home right now but I’ll have a better dig through the menus one more time before the fight. Failing that, I think I’ll try the bt player online and just watch it on my computer. I’m guessing that should be straightforward?
Message 13 of 15
Sorry my mistake it was on my youview box
Message 14 of 15
Sorry it was on my youview box
Message 15 of 15
Eventually found the BT player app and was able to purchase the fight through that. Many thanks.
