Message 1 of 3
Cancelled TNT sports
I cancelled TNT sports on 7th May and got an e mail to say it will be stopped on 6th June (which is the 30 day notice period) . However I can no longer get TNT sports, so it seems to have been cancelled immediately, is this correct?
2 REPLIES 2
Message 2 of 3
Re: Cancelled TNT sports
Definitely not correct.  It may have been caused by your old monthly pass, which is on the same BT ID.
I've re-enabled it now, but you'll need to activate it again through MyBT.  When it takes you to the discovery+ site, be sure to use the "Sign in" button in the top right corner to pair your subscription with your existing login.
Sorry for the inconvenience.
Message 3 of 3
Thank you, I spent 2 hours on the phone yesterday and speaking to three different people who all said different things and none solved the problem.
You have sorted it.
