Message 1 of 2
IPC6023 error message
Is this still working for you?
I have tried every step you have taken. Had about 5 different engineers out, had many many multiple phone calls to BT but no-one seems to be able to fix the problem.
Is there anything you can do @NeilO  or @Les-Gibson ?
1 REPLY 1
Message 2 of 2
Re: IPC6023 error message
Hi @Sandpit
Thanks for your post and welcome back!
I am sorry for the IPC-6023 error message you're seeing. I appreciate the amount of engineers that have visited for this to remain unresolved.  It's likely a configuration issue and we'll be able to give you a hand from here to get it sorted.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
