Message 11 of 19
Re: MotoGP sound out of sync
Sound out of sync again.
BT box pro locked up, unable to watch on that.
BT what a shower of ............
Message 12 of 19
BT app has thrown an error and stopped.
BT Sport2 on my box pro shows a blank screen,  other sport channels OK.
Message 13 of 19
Hi @freddie5 I'm so sorry about that, what error did you get on the app? I just checked my BT sport app and saw no issues with the MotoGP feed. Have you tried rebooting the pro box to see if that helps?
@DarrenDev are you able to help?
Neil
Message 14 of 19
No, as hopefully the pro (LOL) box is recording and didn't want to stop that.
Although the feed for the Pro box just shows a black screen on BTSport2.
The sound on the app when casting seems to have synced again.
Not happy,  the only reason I have BT is for MotoGP.
Message 15 of 19
I'm guessing the app threw the error when the stream was switched - I asked the guys to restart it as a result of you saying it was out of sync again. It should work straight away again though.
Not sure about on the Pro box though - the restart won't have affected that.
Message 16 of 19
It's about time you got this issue sorted, seems everytime I watch it I'm plagued with issues.
Message 17 of 19
We're only 24 days from TNT Sports taking over, so we're not changing/fixing anything on our side.
Message 18 of 19
Your not kidding.
Whilst I'm paying you for a 'service' I would expect BT to sort out any problems, basically your saying its not our problem in 24 days so why bother.
Like I said, BT shower of xxxx.
The move to TNT will hopefully iron out these stupid issues BT can't, or can't be bothered, to resolve.
Message 19 of 19
It's a fault with our encoders for sure. It would take longer than 24 days to raise it, have it investigated by the software provider, have them develop a fix, fully test it, and schedule a deployment to our servers. There's also a chance it'd break something else. Not worth the risk when we can fix it just by restarting the service.
I will try to find out why it wasn't picked up by our support guys though, as I was assured that it would be closely monitored so that it didn't affect customers.
