Message 11 of 15
Re: Discovery + basic, but should be Discovery + premium with my TNT sports subscription
I am active.
However,  active at the basic tier.
I need to be active on the premium tier, because  I have TNT sports.
Message 12 of 15
@ChiChibee Thank you for confirming, if it showing as activated on that link already when you try,  please get in touch as one of our guides will need to take a look at your account to help fix the incorrect tier Fix TNT Sports | BT Help
Alex
Message 13 of 15
Thank you.
I called and one of the guides sorted it out.
I had to re activate and after the activation, I was on the discovery + premium tier.
Message 14 of 15
@ChiChibee That is great to hear, glad it was sorted quickly for you. Thanks for coming back to share the update.
Alex
Message 15 of 15
For all BT  customers  with TNT sports subscription , who have been activated in the Discovery + basic tier  instead of Discovery + premium.
Call BT customer service to have it sorted for you!
