Message 11 of 22
Re: Tnt ultimate not working
I believe that a minimum download speed of 44 Mbps is required before BT/EE will permit channels 433 & 465 to be supplied to a customer. I’m sure that someone from BT/EE will confirm this or clarify the current position if it has changed.
Message 12 of 22
Thank you.I will take this up with them to Clarify.
Message 13 of 22
Correct - your line isn't fast enough to watch Ultimate on your TV Box. BTP-11169 means no eligible product could be found to offer you.
Message 14 of 22
I pushed and pushed and eventually got through to someone called Colleen, who was superb, via the bt business chat on messenger. What I can make of it is that something technical that we can't access in the background had to be reset and now I have ultimate and ultimate hdr working perfectly. My bb maxes at 37mb and 4k is perfect.
Message 15 of 22
Not necessarily. I got this message but the issue was resolved.
Message 16 of 22
We’ve got Halo 3+ with the EE Hybrid which kicks in when our broadband goes down. On the rare occasions that the broadband has gone down, channels 433 & 465 are still perfect even though we’ve dropped to 30 Mbps via the Hybrid.
Message 17 of 22
You sure about that @Brucemeister5 ?
Last I checked, we didn't support multicast over 4G?
Message 18 of 22
@DarrenDev  I tested the speed to see what we were getting and it was 30 Mbps. If you don’t support multicast over 4G, that would mean that none of the subscription channels would work wouldn’t it? I can tell you 100% that they do and we’re using BT mini connectors too!
Message 19 of 22
I've just checked with our experts - we definitely don't support multicast over 4G. The discovery+ app would continue to work, but the channels wouldn't.
The only explanation we can think of for your scenario is that the broadband service was restored, but the hub hadn't realised yet - the multicast follows a different path.
Message 20 of 22
Our broadband went down last Sunday morning at 09:32am just before I left for the gym. The whole village was down according to those I spoke to at the gym. It was down for about 5 hours. The white light was on the EE Hybrid. I was watching sports channels when I returned without having to resort to the apps before the broadband was restored at around 3pm.
