Message 1 of 5
btsport
Dear Community,
is it really true that you cannot use the BTSPORTS APP on a Sony tv?
thanks
Lowcross
4 REPLIES 4
Message 2 of 5
Re: btsport
Depends how new the TV is. If it's one running Android TV or Google TV (which is pretty much every Sony TV for the last 8 years), then you'll find the BT Sport app in the Play Store.
Message 3 of 5
Re: btsport
Mark,
thanks for your reply. The TV is indeed <8 years old and I do have google play store where I have located the BTsports app. The problem is when I press install the app just hangs. It says pending on the screen and does not progress from this status. Previously the app worked on this tv but recently has failed to open. My original question of using the app on a Sony android tv related to advice from BTsports helpdesk which told me the app would not work on a Sony tv (which I could not believe) as it had previously worked. Previously I had  uninstalled the app having been told it may be out of date and that I should install the most up to date version. Hence the current situation. Any further advice would be most appreciated
thanks again
Lowcross
Message 4 of 5
Re: btsport
I had someone with these exact same symptoms just a couple of weeks back. We went through all the usual diagnostics including clearing the Play Store cache, and resetting Play Store completely, but nothing worked. He ended up factory resetting the TV, which sorted it.
Message 5 of 5
Re: btsport
Hi Darren,
thanks for your message.  It looks like I will have to bite the bullet.
Most appreciated
Lowcross
