Message 11 of 14
Re: Now TV channels on EPG
Hey @Smithwade45
Sorry for the inconvenience here, I have fixed the issue remotely for you.
You may need to pop into the settings on your TV Box and complete a software update check.
Message 12 of 14
Thanks for this - all fixed
Message 13 of 14
Hi @Starman, did you get a chance to try the password change and if so has that resolved the error?
Cheers
John
Message 14 of 14
Hi @Starman, thanks fore your PM to confirm this is now fixed for you. I'm sorry that it has taken longer than expected to get it fixed.
Cheers
John
