Message 41 of 46
Re: SHORT RECORDINGS. “STILL"
This is my view.
If as has been indicated that this is not a BT problem, if it wasn't, then every other provider of TV recording boxes would also have the same recording problem of short recordings, which they don't! If they did the Internet would be awash with complaints. Only BT has the problem and in the name of good customer service, they should sort it out forthwith.
Message 42 of 46
Hi Budhabaker.
As you may be aware, I’ve been posting this problem for “years” and as far as I’m aware, NOBODY from BT even looks at this site...
I’ve tried everything I’ve been made aware of, from changing the hardware downward, and it still occurs on a regular basis,  VERY annoying.
If BT/EE cared about this community site then something would have been done, EVEN to acknowledge, and perhaps admit defeat….
Message 43 of 46
Hi Barry T33,
Yes, I've seen some of your entries regarding this problem. Perhaps another approach would be to write to the editors of the Daily Mail, Express etc. trying to get them to write articles regarding the lacklustre support provided (or not really provided) by BT. That way getting it into the mainline press could bring negative pressure to bear on BT for them to take the problem seriously.
I myself have experienced this problem. Most programmes record full length except the programme series from Australia about searching for Gold. Just these programmes, on my BT recorder, only record the first 10 minutes of each programme. Other programmes record early and end early.
Are you aware that these boxes are actually rebadged HUMAX recorders, perhaps contacting them could lead to a resolution?
Bill
Message 44 of 46
I have the same problem - engineer been and said can’t do anything as it is re problem above his pay grade. Spoke to executive complaint at BT and he said no one else has this problem which is not true as engineer said numerous complaints to him in last six months- what to do? Recordings cut short all the time and when fast forward goes back to beginning. Really bad
Message 45 of 46
@Madge232
        Not sure if this is relevant but I had similar problems to yourself for some while and problem re-occurs still sometimes but nowhere near as bad.My problem is evidently linked to Subtitles so I'm wondering if you use them also and if you have noticed that your problems stem from "tinkering" with them (seems to sometimes cause current Recordings to stop and displayed Channel to revert to Channel 1 BBC1).Anyway,Good Luck.
Message 46 of 46
Thanks for your help. Rang complaints at bt today and their attitude was if you don’t like it leave as there is no problem😩
