Message 21 of 27
Re: btp-15000 error
Thank you!!!
Message 22 of 27
Re: btp-15000 error
That's it now fixed @Ldm1 - are you able to confirm?
Message 23 of 27
Re: btp-15000 error
It is so thank you for doing what no BT operative seemed to be able to achieve... but I am so confused about how anyone was able to rectify it with no account details!?!?! If you could message me to enlighten me I would really appreciate it because it feels a bit dystopian 😵‍💫
Thank you
Message 24 of 27
Re: btp-15000 error
Logging into the forum with your BT ID and/or posting from your home broadband connection allows a restricted group of BT/EE employees to identify your account. This speeds up the fault diagnosis and fix process significantly.
I'm glad it's now sorted for you, and sorry that it took so long - unfortunately everything looked correct on the high level system that our call centre agents can see. It's only TV account specialists (of which I used to be one) that know the potential lower level causes of your issue, enabling a faster fix.
Message 25 of 27
Re: btp-15000 error
Ahh the home broadband connection, makes sense!
Thanks so much for fixing it, it ends months of kafka-esque phone calls. Really appreciate you taking the time to do this.
Message 26 of 27
Re: btp-15000 error
Can Derren help me I have the same issue and help desk can’t help
Message 27 of 27
Re: btp-15000 error
@manutd88 I’m afraid not. Darren left BT/EE at the end of October.
