Message 11 of 12
Re: Cost to replace cable from mast to house?
Thanks, reported it and got a reference number.
Message 12 of 12
The engineer will only make safe the wire, normally by just cutting it. he/she will not put it back up.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
