Message 1 of 15
Moving the Openreach box is a pain
Hi all.
Hopefully someone will have an idea as what do I need to do as I have been exchanging emails with Openzone for last 3 months and despite sending numerous photos, specifying what I need to do etc, I'm not getting anywhere!
Essentially we are going to build a front porch/hallway extension thing, but, both Virgin and Openzone boxes are in the way. We use BT for our internet.
Virgin confirmed that we can take box out no problem.
I have asked Openreach to move box ideally to the side of the house as that's where the actual internet box is anyway.
So..
Q1- is that possible? If not what are the options? This box is hanging off the wall and I didn't agree for it to be there. It's also unsightly.
Q2- I can take Virgin box out but why are the cables going from Openreach box to Virgin to the side of the house?
Thanks!
14 REPLIES 14
Message 2 of 15
Re: Moving the Openzone box is a pain
https://www.openreach.com/building-developers-and-projects/altering-our-network/altering-our-network...
You enquire directly with Openreach ( not Openzone ) if you require the ‘network’ relocated because of building changes, it doesn’t really matter if you didn’t agree to its current location , the building owner before you ( or before them ) agreed to it , possibly it was the company that built the property ,  when you bought the property that agreement continues your ownership, it’s pretty standard .
Requesting an Openreach network shift isn’t ‘free’ , and as far as I know , it’s a two part thing , you arrange a paid for survey , the ‘planner’ visits , agrees what’s needed , and who will do what ( if your builder will do any required excavation in your ‘land’ for example that reduces costs to only the work Openreach do ) , once the scheme is agreed and you accept costs , the survey fee is deducted if you proceed , if you don’t proceed you have still paid for the survey, then the  network is moved.
Any proximity between the VM network and Openreach is coincidental, there is no ‘connection’ , they are totally separate
Message 3 of 15
Thanks,
I meant Openreach rather than Openzone 🙈.
I gathered there will be cost.
What is the actual brown box for? As I said 3 months of back and forth and I'm not getting anywhere!
Message 4 of 15
Openreach ‘underground’ or wall mounted residential ‘kit’ generally is grey in colour , VM or the cable company’s that became VM tend to have green underground ducts and can have brown wall blocks, if the wall mounted equipment is brown it’s not likely to be Openreach, perhaps you can take a photo and post it here to aid identification
Message 5 of 15
Message 6 of 15
Message 7 of 15
Re: Moving the Openreach box is a pain
What service, if any, do you get from Virgin? If you don't get any service from Virgin, what did you or someone else get from them in the past?  I am wondering if the Virgin box is used at all, or if someone has gone from the BT/Openreach/Openzone box to the Virgin box then round to the side of the house. When you say that is where the Internet box is anyway, is that the BT Hub / Router inside you are referring to or some other box such as a master socket?
Message 8 of 15
We used to get service from virgin but no longer do.
I 'think' I just worked out a different solution. IF the grey openzone box is the thing that brings the internet/phone to as far as outside the house, instead of side of the house, I will get it relocated to wall adjacent. And then get  BT to put router/phone line next to it. Then can get rid of all cables from outside the house. Thanks
Message 9 of 15
Your photo suggests the line from the BT box may just go under the Virgin box and not into it, have you had a close look to see exactly where it goes?
Message 10 of 15
One cable goes past it but the ither one definitively goes in. We had Virgin broadband and phone line, so perhaps phone line?
Either way I'm happy to get rid of phone altogether, we just use internet
