Message 11 of 13
Re: Raising an ORDI?
Hi John - Unfortunately, that is incorrect as well 😞 The word cottage is missing off both of them.
Message 12 of 13
Hi @sdc and thanks for checking that.
The address needs to be correct on Royal Mail so you'll need to get that sorted before Openreach can update their records.
Cheers
David
Message 13 of 13
OK, thanks for your help.
