Message 381 of 952
Re: BT Webmail Feedback
My biggest issues are the way that the body of emails are now formatted with words being randomly split across rows making it difficult to read, and the 'delete' option being inside the row of options rather than at the end.
Come on BT, please sort this. It looks as if these changes have not been properly tested
Message 382 of 952
Re: BT E Mail
I'm finding that really annoying too!
Message 383 of 952
Re: Spaces between each email line since update
It may be 'expected behaviour' but it's really annoying!
Message 384 of 952
For information of those who have not read other posts about BTMail, this has been posted on the forum by the moderators.
Webmail migration update - BT Community
Message 385 of 952
I have never had so much porn spam in 20+ years and I HATE as in HATE the new email format.
Right, so I signed up for a new contract and this completely rubbish 'upgrade' happened. Is anyone at BT listening?
The font is **bleep** especially if you have poorer eye sight.  Nothing works as it did.  I need to see the attachments not look for them.
I've received more porn than I've seen in the last 20 years in the last 20 days.
Absolutely useless email presentation.
If it ain't broke don't fix it.
Message 386 of 952
Re: I have never had so much porn spam in 20+ years and I HATE as in HATE the new email format.
@Skellie1
I have moved your post onto the "Feedback" thread for the "New" BTMail so that everything is kept in the same place.
See link
Message 387 of 952
Great. Am so pi...d off I can't tell you!
Message 388 of 952
@Skellie1
A nice easy quick fix is to download and use an email client/app such as Thunderbird or Bluemail and you won't need to use the "new" BTMail interface at least until BT issue the fixes.
Message 389 of 952
Keep reporting the messages as spam and one day, when H*ll has frozen over BT might actually do something about it.
If the upgrade is supposed to ensure safety and security it has about as much success as a chocolate fireguard... And more holes than swiss cheese.....
Message 390 of 952
Email Issues
I'm not a fan of this new email update.
It is very clunky and doesn't seem to work properly.
If I do a Reply All, as opposed to just Reply, then there is no Send button... the only option is to save as draft... if you do that and go to drafts, you still can't send it.
Very frustrating!!
Any suggestions - thanks.
