Message 21 of 126
Re: Im unable to enter email address when trying to compose and send an email. I can receive and rep
This problem has started for me today for the first time. There was a Firefox update shortly before but that might be coincidence. When I start entering an email address for sending, the possibilities ( with e.g. name(s) and email address(es)) appear in a box drawn presumably from  Contacts, But when I click on the right choice the details disappear leaving a red box with the letters I have typed and an x for deletion. That is the same result as if you type in letters for a contact which does not exist.
I have checked Settings and the box for auto-filling contacts is ticked. I am using a Windows(11)  laptop.
If I compose an email using on my wife's Ipad I the auto-filling works fine.
Much appreciate any help in solving this.
Message 22 of 126
For info if it helps, I took the Firefox update on the 13th Jan and sent loads of emails successfully up until yesterday morning 16th Jan, noticed last night and this morning the problem began.
Message 23 of 126
  • That was exactly what happened to me Tge problem did not occcur on the day of the Firefox update but 3 days later starting January 16 th and in 17 Have yet to try again this weekend
Message 24 of 126
Stopped autofilling addresses on new emails
After using BT email for years, all of a sudden it has stopped autofilling email addresses in the 'to' box when composing new emails.  I have to type the email addresses in full each time.  This applies when using my Lenovo desktop with Firefox.
The autofill works when composing on iphone or ipad.
All the addresses are there in my contacts and I have checked that the autofill box is ticked.  I have disabled and reticked the boxes but the problem persists
Any ideas welcomed please!
Message 25 of 126
Re: Stopped autofilling addresses on new emails
Welcome to the Community, @CHerrod.
We've had an existing thread around the same issues you've mentioned here, so I've merged your post into this wider thread.
From what I've seen it's just Firefox affected here, and our email team are aware and investigating further now 😊
Using an alternative browser should work in the short term, but rest assured we're looking into getting things working as they should be on Firefox as soon as we can.
Peter
Message 26 of 126
Thank you - much appreciated
Charles
Message 27 of 126
Email auto addresses
Auto address via Firefox still not working and very inconvenient - hopefully B T will fix soonest.
Message 28 of 126
Re: Email auto addresses
@DerekWilliams
Have you considered binning off Firefox and using a different browser? I used Firefox for years and then I discovered Brave. I wouldn’t personally go back to Firefox, but if it’s what you’re used to, then it is what it is.
Message 29 of 126
I am also experiencing this and also am using Firefox so will simply wait for Firefox/BT to do the fix.
However, as a temporary "get-round" rather than having to type the whole email adress  in full you can click on the word "To" on the "Compose" page - this will produce a drop-down list of all your saved contacts and a search box.
If you put what you would normally have put after the "to" prompt into this search box, e.g."Fred" it will find his email and you can click on it and it will appear in the "To" line as it used to.
Saves a little time if you don't want to have to copy the desired email address from somewhere.
Hope this reduces some of the frustration!
Message 30 of 126
Hi Bernard
many thanks Will try this first thing tomorrow
