Message 71 of 126
Re: Auto contacts not working
It appears to be a Firefox problem not least because it works on all other browsers and coincided with a Firefox update!
Message 72 of 126
Has anybody contacted Firefox about this problem? If so what was the response? Thanks.
Message 73 of 126
I could not find a method of contacting Firefox.  However I have asked BT to work with Firefox to correct the problem.  No reply yet!
Message 74 of 126
To make a report to firefox Top right hand side application menu (3 bars), option, report broken site option.
147.0.3 (64 bit) has not fixed the problem in Windows 11 haven't tried windows 10
Message 75 of 126
Thank you for advice re contacting Firefox as I have struggled to do this also Just to say I have tried with Windows 10 and no joy also set computer back in time and still not fixed
Message 76 of 126
Thanks. Done after much faffing. Need to be  signed in to your account , and account screen open. Otherwise grayed out. Await a reply
Message 77 of 126
Sorry if being dim but have never had a Firefox account I just use it ?
Do I have to create an account and if I do any implications ?
Message 78 of 126
An account lets you Save and synchronise passwords across all your devices that use Firefox. You can also send a tab to a different device.
Read about it here.
Get a Mozilla account – Keep your data private, safe and synchronised — Mozilla
Message 79 of 126
So I have to get an account ( I don't need one ) so that I can lodge a complaint/ask for help? Correct ?
thanks
Deb
Message 80 of 126
Was that not what you were told!
