Message 1 of 4
Email on browser
It keeps saying user name incorrect
3 REPLIES 3
Message 2 of 4
Re: Email on browser
Are you entering your self or are you using the browser's autofill to put in the address.
If using autofill try entering it and your password yourself.
Message 3 of 4
Thank you that worked
Message 4 of 4
Hi @jayed2
Thanks for coming back and letting us know the great advice from @gg30340 helped get this sorted for you.
We appreciate the update 🙂
Leanne.
