Message 11 of 13
Re: Unable to add second BT Internet Email to Classic Outlook using Microsoft 365 Windows 11
After setting up on Thunderbird, I have tried yet again and got it to work.
Outlook is the problem.
Thanks again for all the help and support.
I believe the ultimate problem lies with BTinternet emails and how they are set up compared to industry standards.
Message 12 of 13
The settings for BT mail ARE industry standards.
Message 13 of 13
Can you explain how if the BTMail settings for email clients/apps are not " to industry standards"  can the hundreds of thousands if not millions of people including yourself when you use Thunderbird, manage without any problems.
I would suggest that the problem is with 29 year old Classic Outlook and its compatibility with Windows 11.
