Message 21 of 36
Re: Webmail Search fails after 11 seconds timeout
Why are BT not doing anything about this.
Has it been officially raised as a fault?
Message 22 of 36
Hi everyone,
This has been fed back to our email support team.
Once we have more information we will let you all know.
Leanne.
Message 23 of 36
I have had this problem of late, and when I spoke with someone, I was advised the same, that due to the large numbers of emails (>100K) is the reason. but Iit was working till recently, so I guuess it isnt to do with the numbers of emails.
Message 24 of 36
I totally agree.
And it would appear BT are doing nothing about it, given the length of time this has been a problem.
Very frustrating.
Message 25 of 36
@rrk3001
To save repeating myself please have a read of messages 11 and 13 which while they are not in relation to the search problem you are having it may be of interest.
Message 26 of 36
Morning everyone,
Our email team have completed investigations and have increased the search function for email folders and the email inbox from 200k to 450k.
This will help timeout issues when searching. If you have more than 450k email in your inbox and the folder you're searching, you will need to move emails to different folders, or delete/unsubscribe from emails you don't need to make sure the email platform has no timing or performance issues.
Leanne.
Message 27 of 36
Thank you for this update @Leanne_T  - For me this has solved the problem.
One of my folders has 205k messages (10 years worth) and search results are now displaying successfully after 14 seconds.
I shall continue to split my messages into a few smaller archive folders to prevent this from being a problem in future, but it's a jerky and time consuming process in the webmail UI.
Knowing the new threshold of 450k is really key. Thank you.
Best regards,
Simon
Message 28 of 36
Glad we could help and the changes have solved your problem @SiGod
Thanks for letting me know.
Leanne.
Message 29 of 36
Hello Leanne - I have had the same problem, and was advised to delete emails. Thanks for the update to 450k. However deleting emails would be so much easier if we could have the Yahoo feature, whereby if you HOVER over an email you get a Search magnifying glass icon so you can search for messages from one sender - and be able to delete en-masse. Will really be grateful if you can have the team add this feature. Many thanks in advance for your kind cooperation. Thanks and all the best.
Tags (1)
Message 30 of 36
Hi @rrk3001
Thanks for the feedback and suggestion. I will share this with the email team.
Leanne.
