Message 1 of 3
Syncing two remote controla
I have two remotes, one for my Philips Smart TV and one for my BT YouView box. At the moment I’m using both, which can be a pain, when adjusting the sound etc. I’ll use one remote, then next the time the other one, which then causes confusion (for me)  Is it possible set one up so that becomes the one you use for everything and the other then becomes redundant? If so which one is best to use? Many thanks.
2 REPLIES 2
Message 2 of 3
Re: Syncing two remote controla
Hi @chris2400, thanks for your post. You can program the BT TV remote to perform some functions on your TV. Have a look at Control My TV With My BT TV Remote and see if that helps you.
cheers
John
Message 3 of 3
Thank you.
