Thanks for your kind words Andy, yes I ll upgrade next year sometime but the next 2/3 months isnt the right time for us.
Just wish i could get hold of bt to tell them that, just tried again but a 45 min wait so will try tomorrow
Try contacting these:
They are more senior than the usual phone help desk and should be able to sort this once and for all.
Thankyou, will try in the morning, much appreciated.
WSH
I got thru to them with your link and spent 48 mins on the phone, he had to keep refering to his manager so took ages. He tells me I've only got to Jan to convert to fibre otherwise my broadband will cease to work. He also said when i convert to fibre id need to agree a new contract . Left it that I'd contact them when we're ready.
Thanks for your help
Just to reassure you, the new contract just means that you'll be starting a new 24 month term. But hopefully at no extra cost if my recent experience is anything to go by.
I think you were misinformed when you contacted BT.
If it is BT and Openreach that are initiating the switch over to FTTP you should not have to start a new Fixed Term Contract other than your present contract will be new in respect to what terminology it uses ie you will be on a FTTP contract instead of a FTTC contract but the Fixed Term end date should be the same as you have at the moment and the price you pay should be the same.
It will only become a "new" Fixed Term Contract if you change to a faster broadband package or change / stop some other part of your present package in which case you will start a new Fixed Term Contract.
They keep putting off the migration orders. If the op wants to do it proactively in their own time then would have to be a new contract on probably a better deal anyway
