Message 11 of 23
Re: 3 months of endless dropped connections, yet BT say there's not a fault
Just from whichever router you are using normally
Message 12 of 23
Ok, thanks. Hope the following is what you are looking for. Hope you can follow it, it's come out a bit upside down:
Internet Connection (IPv4)
Connection Type:
PPPoA
Login Status:
Connected
Internet Address:
109.151.110.242
Subnet Mask:
255.255.255.255
Default Gateway:
172.16.14.187
DNS1:
81.139.56.100
DNS2:
81.139.57.100
DNS3:
MTU:
Auto
DHCP Server
DHCP Server:
Enabled
Start IP Address:
192.168.1.100
End IP Address:
192.168.1.149
Client lease time:
1440
2.4 GHz Wireless Network
Status:
Enabled
MAC Address:
48:F8:B3:C6:A0:E4
Mode:
802.11bgn
Network Name (SSID):
Channel Width:
Auto
Channel:
6
Security:
WPA2 Personal
5 GHz Wireless Network
Status:
Enabled
MAC Address:
48:F8:B3:C6:A0:E3
Mode:
802.11anac
Channel Width:
Auto
Channel:
Auto
Security:
WPA2 Personal
PVC Connection
Encapsulation:
PPPoA
Multiplexing:
VC
QoS:
UBR
PCR:
4000 cps
SCR:
4000 cps
VPI:
0
VCI:
38
Modulation:
MultiMode
ADSL Connection
Status:
Up
Downstream
Upstream
Data Rate
7906.25 kbps
437.50 kbps
Output Power
19 dBm
12 dBm
Noise Margin
8 dB
16 dB
Attenuation
22 dB
19 dB
Message 13 of 23
Extremely tired of this
39.160000) Wire Lan Port 4 up
23:42:49, 25 Apr.( 34.010000) WAN Auto-​sensing running.
23:42:47, 25 Apr.( 31.430000) System up, firmware version: 4.7.5.1.83.8.130.1.32.1.3 (Type A)
23:42:43, 25 Apr.( 27.550000) WPA2 mode selected
23:42:43, 25 Apr.( 27.550000) WPS enabled
23:42:41, 25 Apr.( 25.770000) WPA/WPA2 mode selected
23:42:41, 25 Apr.( 25.770000) WPS enabled
23:42:36, 25 Apr.( 21.210000) System start
22:42:05, 25 Apr.(22772.610000) ETHoA is up -​ VPI: 0, VCI:35
22:42:05, 25 Apr.(22772.610000) DSL is up
22:42:05, 25 Apr.(22772.580000) DSL noise margin: 27.00 dB upstream, 8.20 dB downstream
22:42:05, 25 Apr.(22772.500000) DSL line rate: 448 Kbps upstream, 8096 Kbps downstream
22:42:02, 25 Apr.(22769.420000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:42:02, 25 Apr.(22769.410000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
Message 14 of 23
Message 15 of 23
Hi @Biscuit2 I'm sorry your connection issues are still ongoing. I can see my colleague @StuartH is helping you with this and he's made arrangements to contact you this afternoon.
Neil
Message 16 of 23
@NeilO
@StuartH
Thanks Neil, yes I hope Stuart can help,  it's been a very frustrating weekend... not sure what we'll do if it can't be properly sorted this time...
Message 17 of 23
@StuartH
Is there any chance we could have an update on our open fault please
Message 18 of 23
@Itsover
On the assumption you mean YOUR open fault, the fact things have gone quiet suggests the problem has been addressed and fixed.
Not everyone returns to provide an update, mark the solution and give a thanks (Thumbs Up button) to the form's hardworking volunteers and the few part-time moderators who are BT staff employed elsewhere in the corporation.
Message 19 of 23
@Carlusha
You are definitely an expert, I agree.  But you may not have known that @StuartH is the person handling the very longstanding fault we have on our line, and as there's been no update for a month we thought we'd ask.  To be factual, it's BT's fault, not ours or yours.
Message 20 of 23
@Itsover
Ah, apologies to all concerned. I shall stand in the corner for 15 minutes.
