Message 1 of 11
ASUS RT-AC88U can't connect to internet
Hi all,
I have recently moved to Fibre 900 and I would like to try an Asus RT-AC88U router to see if I can improve wifi speeds and coverage in my home vs the BT supplied router.
I am advised that I should use the following login details over the PPoE connection:
username: [email protected]
password: BT
However the router is not able to connect to the internet. I manually installed the latest firmware and I still have no joy getting internet. After speaking to Asus support, one of the advised steps is to connect a PC/Mac direct to the modem, I assume to check I am getting internet in, but I don't get anything. I am not sure if this is a related issue, as I get internet fine when I use the BT router. I also managed to get the internet with a Netgear router but I returned it as my speeds were halved for some reason, hence now I am trying with the Asus.
Many thanks for any help.
10 REPLIES 10
Message 2 of 11
Re: ASUS RT-AC88U can't connect to internet
ASUS have clearly given you poor advice as your broadband connection clearly works with other routers.
The PPPoE details are correct and I can only suggest trying a factory reset and starting again. If that fails it is possibly a faulty device.
Message 3 of 11
@ElliotNewman
_____________________________________________________________________________________________
Forgive me for asking the obvious.
Why (if you haven't bought it yet) would buy a modem router Asus RT-AC88U when the Asus RT-AX88U cable router is the one for the job on the FTTP 900 - 110 package.
Asking for a friend . 😁
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 11
The Asus RT-AC88U doesn't have a modem - it is a router hence the model name starts with RT.
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 5 of 11
@brookheather
Ahh my bad. Sorry.
Message 6 of 11
Hi all,
Thanks for all the replies. Yes I don’t need a modem-router since BT Fibre comes with a standalone modem.
anyway, now onto the good news - it’s working! I’m writing this message through the WiFi of the ASUS!
I hard reset the router as advised, but first made sure the latest firmware was installed. I then used the ASUS router IOS app to setup the router and it’s all working!
Message 7 of 11
What speeds have you achieved, Wired and WiFi.
Message 8 of 11
@busterboy1  Its the ASUS DSL xxxx models that have a modem
Message 9 of 11
Noted
Message 10 of 11
I get 850-900 wired with a 2019 MacBook Pro. On the same laptop I get about 700 when close to router on WiFi.
my 3 year old iPhone X seems to top out at about 350, in all rooms in the house. My wife’s newer iPhone SE gets about 500, at least in the one room I’ve tested.
in a three story house, not too bad!
