Message 1 of 2
Advance phone set up
I have recently purchased a advance phone 3 handset 090640. I have set it up with the wizard. The Telephone now rings , but when I try to answer there is just a buzzing noise. If I return it to the cradle it will keep ringing. Also I cannot make any out going calls. It sounds like its dialing the number to let you know the number is ringing but then also goes to a buzzing sound and won't connect.  Any suggestions please.
1 REPLY 1
Message 2 of 2
Re: Advance phone set up
Hi @Stevecav
Welcome to the community and thanks for posting.
Have you experienced these issues with another phone?
If not, I can only suggest calling the support desk on 0800 145 6789 they'll be able to assist with this.
Stuart
