Message 1 of 4
BT App will not connect to Hub
 The MyBT app will not connect to my hub.  I have tried a factory reset. I have a new disc that I want to add in and name but without access to the app I am scuppered. Help please!
3 REPLIES 3
Message 2 of 4
Re: BT App will not connect to Hub
Is your device connected to the hub wifi?  If so then can you see the hub and try and connect using the admin password
Message 3 of 4
Hi Molly. Thank you for your reply. Unfortunately I do not understand.  Where can I "see" the hub and where do I enter the admin password to start the disc setup protocol? Thank you...
Message 4 of 4
If you are using the MYBT app then you need to connect to hub and then the discs.   You need to be connected to your home network then should be able to continue to connect to your hub which will need you to enter the admin password from the back of the hub
