Message 111 of 133
BT Cloud
My desktop BT cloud has logged itself out. On trying to sign in I get the message "It does not look you're eligible for BT Cloud on this BT ID. Please check you are logged in using the primary BT ID for your broadband account. Alternatively access BT Help for Error Code UN2.
On trying to access the cloud via "My BT" i get the message "Sorry, there's been an error while fetching your cloud details.
Is there a known problem at BT? I've tried ringing twice. The first time I lost the will to live after hanging on for a very long time. The second time, after a 10 minute hold, someone appeared to answer but immediately dropped out with a recorded message saying "Sorry there's a fault" - I found that ironic!
Message 112 of 133
Re: 'It doesn't look like you are eligible for BT Cloud on this BT ID' error code UN2
Same for me - I can now log in.
Message 113 of 133
So is it now working?
Message 114 of 133
Seems to be working again now.
Message 115 of 133
Yes, it now seems to be back up.
Message 116 of 133
yes mine is up and running now
Message 117 of 133
Up and running for me now too.  Phew.
Message 118 of 133
BTCloud log in is working, but Broadband connection dropout during file synching is as bad as ever.
Message 119 of 133
Thanks all for the replies, it's working now.
Message 120 of 133
Yes its up and running now thanks goodness
hope it stays that way
