Message 11 of 13
Re: BT Digital Voice
Hello Keith
Our current Bellset looks like either the 48 or the 50B.
Do you think it is possible to get this to ring again now we have been 'forced' by BT to have "Digital Voice" via fibre optic wires (FTTP)?
Alan
Message 12 of 13
Both of those look like they may have an internal capacitor which is strapped in.
The simplest way to try, would be to disconnect your home wiring from the external network, and the link the home hub phone socket into the internal wiring using a patch cord, as described on many of the other threads on this board.
As it worked before, on your copper line, it should work on the home hub output. All you can do is to try it.
Message 13 of 13
 Keith
Many thanks........will get my ex BT friend to give it a try.
Regards
Alan
