Message 11 of 19
Re: BT Fibre 900
i know just need to figure out how to use the BT voice phone with it .
Message 12 of 19
Re: BT Fibre 900
Glad you got there in the end Tom.
Enjoy the new ultrafast internet. 🙂
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 13 of 19
Re: BT Fibre 900
@tomhumph97
______________________________________________________________________________________________
I still have my original copper service running for the home phone but look forward to you getting that working mate.
Please update this page if you do. 🙂
Message 14 of 19
Re: BT Fibre 900
If that's the digital voice handsets I believe they only work with the sh2
Message 15 of 19
Re: BT Fibre 900
@garybs29correct. To use digital voice you have to use the SHub.
Message 16 of 19
Re: BT Fibre 900
Correct
Message 17 of 19
Re: BT Fibre 900
There is a long thread on the subject here on TBB forums stating the same.
Message 18 of 19
Re: BT Fibre 900
@busterboy1
is this the same router you have?
ASUS RT-AC88U
Message 19 of 19
Re: BT Fibre 900
No mate mine is the RT-AX88U Dual Band AX6000 as pictured here hence the higher price tag.
The router you have listed is not WiFi6 enabled but will serve you well via ethernet but a lower WiFi speed.
