Message 11 of 24
Re: BT Hub Blocking Access to a Website
What message does it show in the address bar when you try to connect?
Message 12 of 24
This is the screenshot of the page I'm trying to view and the error message. In this instance I'm using Microsoft Edge.
Message 13 of 24
If you click on the circle with the "i" in it to the left of the web address what information does it give?
Message 14 of 24
Can you reach it ok if you change your DNS settings to 8.8.8.8 and 8.8.4.4 rather than obtain from the hub.
Message 15 of 24
This is the message received when I click on the i button to the left of the web address
Message 16 of 24
At the foot of the message below "Tracking Prevention"  where it shows the sites web address can you try changing it from off to on.
Message 17 of 24
I just changed my DNS settings to 8.8.8.8 and 8.8.4.4 and the site is still not reachable.
Note that I cannot ping the website. The only temporary fix is to restart my home hub.
Thanks,
Message 18 of 24
If you can not ping it forget trying anything with the browser.
Message 19 of 24
Tried tracking prevention in both Off and On. Unfortunately the site is still not reachable.
Message 20 of 24
When you are blocked from the website are you able to access other sites without problem?
