Anonymous
Not applicable
Message 11 of 13
Re: BT McAfee Anti Virus Reactivation
How often does that come up and does it then just go away with everything continuing to work properly?
Message 12 of 13
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They are very busy at present so it can take up to 48 hours for them to contact you. They will do this by posting on this thread.
Message 13 of 13
Hi @FTW
Welcome to the Community and thanks for your post!
I'm sorry that you're having problems reactivating BT Virus Protect on your second PC.  There has been some good suggestions by the guys on the thread.  Sorry these didn't work and you're in the same boat.
We are going to have to pick this up and give you a hand.  We are extremely busy at the moment and we will get back in touch with you as soon as we possibly can.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
