Message 1 of 5
Parental Controls not working
Hi there,
My parental controls have just stopped working and even though I have ticked the relevant boxes its still allows one to see explicit content which is very concerning.
Any help would be much appreciated.
4 REPLIES 4
Message 2 of 5
Re: Parental Controls not working
Hi @Peter48 welcome to the forum and sorry the Parental Controls are not working as that is concerning.
Are you using a VPN?
Check you are using BT's DNS settings?
Post back and update us,
cheers
John
Message 3 of 5
Hi JohnC2
To be honest, I'm not sure but I think we do have a VPN as a friend set it up for me but the parental controls have been working just fine until recently. Is there a default re-reset that I can do?
Message 4 of 5
Hi @Peter48 You would be best to check with your friend and confirm if a VPN is set up. The VPN can be used to circumvent the parental controls.
Cheers
John
Message 5 of 5
Thanks JohnC2
Ill check and get back to you.
