Message 11 of 19
Re: BT Smart Hub 2 and DiY Access Point
Sounds like a problem with the device somehow not changing to the different wifi source. I assume the hub and Netgear have different SSIDs
Message 12 of 19
No, I've given them the same SSIDs. I'm going to start over with a hard reset with the Netgear direct to BT SH2.
Message 13 of 19
Try giving the Netgear a different SSID, never a good idea to have multiple devices with the same SSID.
Message 14 of 19
Hi @licquorice ,
Different SSIDs assigned but still same issue. The Netgear router is listed on the SH2 as;
Does this look right at the SH2 end? I was expecting to see the IP address I've assigned to the Netgear router there?
Thanks!
Message 15 of 19
The SH2 network map is a complete dogs breakfast and can't be relied upon for accurate information.
Message 16 of 19
Log on to a PC or laptop which is connected directly to the SH2, open a command prompt (Win+R then type CMD), and then type in ping followed by a space and the IP Address you gave the Netgear. If you don't get a reply then the connection hasn't worked. e.g. ping 192. etc
Message 17 of 19
@licquorice @Les-Gibson after trying a number of different tweaks, I decided to have a go with an old D-Link router. Changed IP and disabled DHCP and it worked a treat! Not sure why the Netgear wouldn't play. I even discovered that it had an AP setting but that still didn't work. Anyway, all good now. Thanks for the responses!
Message 18 of 19
Strange, but pleased to hear you got a solution.
Message 19 of 19
No problem, was the netgear OK the last time you used it?
