Message 11 of 39
Re: BT Smarthub 2 keeps disconnecting
yes i have
Message 12 of 39
did you receive Hub stats?
Message 13 of 39
yes managed to see stats and obviously connection time very low  and the constant restarts have caused the DLM to take action and reduce your connection speed and increase your noise margin in an attempt to stabilise your connection
was quiet line test totally silent?
have you managed to try using test socket with a filter?
Message 14 of 39
I think the quiet line test is ok.  I am not using a filter as BT say a filter is not necessary with a smart hub 2.  Any ideas?
Message 15 of 39
the quiet line test should be absolutely silent when using a corded phone    any noise on line is a problem
you need to use a filter if you connect your hub to the test socket to see if that stabilises your line
which master socket do you have
Message 16 of 39
BT are talking nonsense, a filter, either incorporated into the master socket or external, is required with all hubs.
You need to use a filter if connecting to the test socket in order to provide a conversion from the rj11 plug that doesn't fit the test socket to a phone plug that does.
Message 17 of 39
sorry i dont understand what you mean?
Message 18 of 39
could you send me your email address so I can send you pictures as I dont see how to attach pictures on this chat?
Message 19 of 39
I have image number 7
Message 20 of 39
if you have master 7 then that is newest master and the faceplate just unclips - no screws.  if you take off master then you can see the test socket and you need to use a filter as described by @licquorice  to enable you to connect the cable from the hub
once connected then repost hub stats and leave hub connected if possible for couple of days and see if now more stable
