Message 31 of 39
Re: BT Smarthub 2 keeps disconnecting
where would i get a new master from? And what what master socket would I need as my phone is also connected to this socket. And would I need an electrician to fit this?
Message 32 of 39
@andreaferns120472 wrote:
My phone line is also connected to this socket, should i still follow your instructions?
See the picture I posted.
Message 33 of 39
I doubt you will need to resort to that, it will just be a bad connection, which may clear itself when everything is re-connected, after proving that is the cause of the problem.
Message 34 of 39
if this is the cause of the problem what do I do?
Message 35 of 39
If this solves the problem then if you have extension sockets then you would disconnect the extensions from terminals 2&5 and try master faceplate back in position.  If problems is still solved then you don't need to do anything but if still dropping then faceplate needs to be replaced
Message 36 of 39
sorry what do you mean if I have extension sockets then I would disconnect the extensions from terminals 2&5?
Message 37 of 39
Do you have phone extension sockets in your home?
Message 38 of 39
I have the main phone connected to the master socket and the other 2 phones are wireless
Message 39 of 39
it's pretty quiet
