Message 21 of 39
Re: BT Smarthub 2 keeps disconnecting
@andreaferns120472 wrote:
My BT Smarthub 2 keeps disconnecting and reconnecting over the past 10 days, any ideas why?
@andreaferns120472
That master socket is known to give problems, and is possibly the cause of the disconnections.
As mentioned https://community.bt.com/t5/Landline/2019-Master-Socket-kit-loose/m-p/1985566#M6775
Message 22 of 39
I have looked at the link and I dont really understand what to do. Is there a video? I have had countless BT and openreach engineers visit our property over the past 18 months.
Message 23 of 39
just unclip the front plate of master by squeezing the 2 sides.  you will then see the test socket  you then need to insert a filter into test socket then connect the cable from the hub into the filter and then hub should connect to the internet
Message 24 of 39
First you need to prove whether that is the issue, by leaving the home hub connected to the test socket for a few days, to see if you still get the disconnections.
If its still fine after a few days, then replace the front filter plate, making sure that its held in tight, and see if the problem re-occurs. Sometimes just re-locating the front section can fix the problem.
Message 25 of 39
So I should leave the plate of the master socket off permanently ?
Message 26 of 39
just for a few days to see if connecting to test socket helps your connection stability
Message 27 of 39
what do i do if leaving the plate off helps my connectivity after a few days?
Message 28 of 39
My phone line is also connected to this socket, should i still follow your instructions?
Message 29 of 39
Either leave it off permanently or get a new master socket
Message 30 of 39
You can still connect your phone to the filter
