Message 101 of 433
Re: BT TV Box Pro - comments/questions
Nothing, just press a number while it is playing back a recording.
Message 102 of 433
Does anyone know if the pro box now comes with the Big Sport package currently on offer? On the website it has a picture of the old one whereas all the other packages have a picture of the pro box.
Message 103 of 433
Hi @leenay , yes it comes with the new box.
Can you show me where you see a picture of the old box on the Big Sport package please? I've tried looking for it but can't seem to find it.
Message 104 of 433
Cheers Darren, here's the package page with the image of the older box at the bottom: https://www.bt.com/packages/big-sport
Message 105 of 433
If my broadband speed is not up to UHD TV, will the Netflix, Prime etc. apps still allow UHD F HDR viewing from them?
Also, anyone discovered why existing customers need to pay the £20 fee?
Message 106 of 433
Netflix and Prime use a maximum of around 16Mb/s for their best quality  -  BT Sport Ultimate used about 29Mb/s.
Delivery and admin fee?
Message 107 of 433
Thanks @ozsat
There is a separate £9.99 deliver fee.
The £20 is called a connection fee, which is strange because I already am connected
Anonymous
Not applicable
Message 108 of 433
Got the new box yesterday all set up in ten minutes. I too was wondering why there is a £20 connection fee.
Must say the picture on the HDR channel is awesome, even the sound is better through the sound bar which is not a high end expensive one.. Anyone know when first football is on there.
Message 109 of 433
If you look on the bt sport app schedule it lists all hdr events. Tomorrow by the way Leeds v Man Utd.
Message 110 of 433
Support documentation update  needed.
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
does not seem to cover the Pro box  maintenance mode instructions.
(there are instructions on the Youview site
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
