Message 1 of 4
BT Virus Protect unable to install Norton
Have just purchased a new laptop and trying to install Norton through BT website.  Account is showing 'Active' but when click on download Norton I get the following message
Norton Security cannot be installed on your operating system
The new laptop is running Windows 11 Home in S mode
Any help would be much appreciated
thanks...Lee
3 REPLIES 3
Message 2 of 4
Re: BT Virus Protect unable to install Norton
Hi @Lee_PV,
Thank you for posting. You would need to switch out of S mode to be able to download BT Virus Protect.
Switching out of S mode in Windows
"Windows 11 in S mode is designed for security and performance, exclusively running apps from the Microsoft Store. If you want to install an app that isn't available in the Microsoft Store, you'll need to switch out of S mode. "
Thanks,
Paddy
Message 3 of 4
Hi Paddy
thanks very much for the reply.
all sorted👍🏼
thanks
lee
Message 4 of 4
Hi @Lee_PV,
Thank you for posting back to update the thread.
Thanks,
Paddy
