Message 1 of 1
BT Whole Home
My BT whole home system has started having issues. Every now and the all devices connected to the network will disconnect and attempting to reconnect gives the error "couldn't obtain ip address. It is still possible to connect to my router when this happens, only whole home is the problem. After a while e.g. overnight, it starts working like normal again. I recently set up port forwarding in order to run a server but have since disabled it.
Tags (2)
