Message 1 of 7
BT disc outside? Or addional device for outside?
Ive bought  x3 discs to work with my sky internet - which works well inside the house but the wifi does not reach the garden at all. I have one disc (with good reception) very near to the bi fold windows but it still does not seem to help.
Can BT disc work outside?
Can I get another specialist wifi extender for outside that would link to my sky internet along with the BT discs?
6 REPLIES 6
Message 2 of 7
Re: BT disc outside? Or addional device for outside?
Hi @Lucien66uk welcome to the community and thanks for posting, are you connecting to the 2.4Ghz SSID when you're out in the garden? The 5Ghz SSID doesn't have a great range so it may not be reaching you outside. The wifi discs are not intended to be used outside as they're not weatherproof but there are various extenders and repeaters that you can put outside.
Neil
Message 3 of 7
Hi Neil,
Thanks for your reply.
I believe its a 2,4Ghz.
So as well as the discs can i also use an extender or repeater at the same time?
Anonymous
Not applicable
Message 4 of 7
Yes you can use wi-fi extenders and discs at the same time but IP66 (Ingress Protection 66) waterproof extenders are not cheap
Message 5 of 7
Amazing thanks for advice.
Yes i know .i eventually want wifi at end of garden so i  may invest.
Anonymous
Not applicable
Message 6 of 7
If there are any outbuildings near where want wifi then I would consider extending it into there
Message 7 of 7
Might it be possible to put a BT disc and an appropriately selected d.c. power supply fed through an IP66 gland into an IP66  plastic enclosure with IP45 ventilation louvres?
