Message 1 of 26
BT is putting a warning and then not displaying my website.
Last year my website was hacked, so I took it offline.
I have just registered it back with a new hosting company with a SSL and it is still giving a warning when entering and then wont connect.
I have contacted BT on various emails to get the warning removed as the site is now cleaned, and a fresh install of wordpress. Nothing has happened as yet.
I have contacted the hosting company on the issue of the connection error, however they have no error. I have connected to the website on my phone using 4G and I also have NO error.
It only seems to be an issue caused when viewing on my BT internet connection.
I have found it is being blocked by:
BT-Strict
CloudFlare Family DNS service
Please can you look at: https://www.defendnattack.com
25 REPLIES 25
Message 2 of 26
Re: BT is putting a warning and then not displaying my website.
The above? Works OK for me.
Message 3 of 26
Works for me as well.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 4 of 26
doesnt work for me.. I get
This site can’t provide a secure connection
www.defendnattack.com  uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Unsupported protocol
The client and server don't support a common SSL protocol version or cipher suite.
Message 5 of 26
What device/operating system/browser are you using?
Message 6 of 26
desktop PC, using chrome and firefox and Windows10. Also on iphone.
Do you think restarting my router may help?
Message 7 of 26
If I were to say you might try changing the DNS to say 1.1.1.1 would that make any sense to you?
BTW - which router are you using?
Message 8 of 26
npoe that means nothing to me.. so not to clued up on DNS etc...
I think its the latest one.. not sure if they need firmware updates
Message 9 of 26
Okay. If  google something like "change DNS settings in Window 10" and then use 1.1.1.1 or  8.8.8.8.
This will change the DNS on you PC. See if that works
DNS= Domain Name Server , which is essentially a rather large index of web addresses matched (eg www.bt.com)  to the actual Internet Protocol Address.
Message 10 of 26
thanks but nope still got the error and just reset the router too 😞
