Message 21 of 26
Re: BT is putting a warning and then not displaying my website.
Yes you actually had a few issues to resolve.
1. BT Web Protect with a warning page to the site - you have now disabled this through MyBT for your connection.
2. The domain itself is actually on a malware/malicious list
- Flagged by Google
https://transparencyreport.google.com/safe-browsing/search?url=defendnattack.com&hl=en_GB
- Flagged by Fortiguard
https://www.fortiguard.com/webfilter?q=defendnattack.com
You will need to resolve the reputation of your domain as it could cause issues for you further down the line if it ends on blocklists and safe/protection systems.
Message 22 of 26
Agree with @jac_95  advice, also look at your SSL certificate, Firefox and Edge flag it as an issue.
Is it self certified ?you can get them for very little these days.
Message 23 of 26
@-Richie-  looks like there's no redirect from http to https which is why you see a certificate error as it's not using the secured connection. Can be configured at webserver or ALB level
Message 24 of 26
@jac_95  Good spot, manually entering the HTTPS works, without it gets flagged as insecure.
Message 25 of 26
thanks all for the help.. it seems that the BT issue has cleared and it is now a safe site issue with the HOST company (fasthosts) and also with trying to clean up where it has been flagged as unsafe (which could take months reporting it to all these different companies)...
once again thanks for all the help.
Message 26 of 26
thanks have ask host to look at this.
