Message 11 of 26
Re: BT is putting a warning and then not displaying my website.
I guess this being blocked by
BT-Strict
CloudFlare Family DNS service
Once this resolved, may resolve the issue. But looks like its a network issue with BT as none of my devices will connect.
Message 12 of 26
BT-Strict
Since it worked for me - I used Edge browser, I tried Opera and Firefox.
Firefox didn't like it, tried to display some garbage but did not error.
I reckon the problem is somewhere within your settings.
Message 13 of 26
not sure what settings as it happens on 3 desktops, mobile phones, tablets and laptop... anything on my BT network has this error. Regardless of browser...
If I take them off my network and use 4G works fine, so would point that its not the PC its the network.
Ill happy try any other suggestions.
Message 14 of 26
Message 15 of 26
Log onto your MyBT and check in "Your Security" that BT Web Protect is turned off. BT are turning it on by default.
EDIT: Snap!!
Message 16 of 26
Thanks for help so far... I have turned the BT Web protect off and I now have been able to remove the BT warning. I know get this error, but I can navigate via it to the visit this unsafe site . And it connects... I was able to also get this by messing around in this part of google chrome.... its not fixed it but I can at least edit the site now! So question is now how do I get BT to remove this RED SCREEN.
Message 17 of 26
Go to https://search.google.com/search-console/welcome
Enter your site's address and follow what Google suggests.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 18 of 26
It is your web browser that is giving you that warning not BT.
Message 19 of 26
OK thanks... Ill give that a try and see what happens.
Just find it odd its happening on my connection and not other BT connections.
Everything on PC is being run to default settings and happens on all devices.
Never come across this before so just frustrating, but thanks for all help once I get the google bit done we can see what happens.
Message 20 of 26
ok so originally I was getting a BT error, it was a BT actual page.
Now im getting this error?!!?
Funny though just tried it on firefox and edge with no errors or issues!!
Think that BT Web Protect could have been causing some issues!!
