Message 31 of 57
Re: BT saying Fibre isn’t available at house I’m purchasing
I wonder if the number you are entering was used at a previous location with BT and is now used with Plusnet at current location but old information is still held on the checker database. The last speed measured on the line was 29/9/2019 from your screenshot.
Message 32 of 57
I attach a screenshot below. Not sure if it means much though. The map is also not correct but presumably that’s because I’ve not put the address in.
I have no idea if it was a show home tbh. They were built around 15-20 years ago. I tried google street view but it doesn’t go back that far.
in terms of the number itself I think the current owner has been there about 13 years so doubt it has been moved since 2019.
thanks
Nick
Message 33 of 57
Probably not what you want to hear, but you are not going to get a definitive answer to this until after you have taken out a service with BT on Monday I'm afraid. I will still wager it is a problem with the database though.
Message 34 of 57
Not a problem.  Thanks for trying your best to help / reassure me.  Although I move on Monday I can't take over the line until 30th as that's 2 weeks notice.  Exchange happened at very short notice so I wasn't able to give BT the full notice.
I will let you know what happens.  If they say computer says no then I will try to get them to at least get to the bottom of if I am connected directly to the exchange as even from my very limited knowledge it would seem really unusual.
Presumably if I am connected directly to the exchange its impossible to switch that to cab 25 even though that's only 50m away and the exchange is over a mile away?
Worst case scenario I will have to put up with slow internet and maybe look to move to a 5g Hub when available.  I am hoping as i'm in a major city that might be in the next year or so.
kind regards
Nick
Message 35 of 57
Post back here and if there is still a problem after the 30th we can see what the options are. Hope the move all goes well, I know the stresses involved as my daughter is in the process of moving house.
Message 36 of 57
@licquorice  I'll wager it's an EO line. Drink on it?
Message 37 of 57
£20 to your favourite charity
Message 38 of 57
Agreed!😁
@nickshaw11  Please let us know how you get on.
Message 39 of 57
Good evening chaps. I thought I would give a bit of an update as I’ve now moved into the property. My phone line doesn’t go live until 30th March though.
out of interest I thought that I would put the phone number through the DSL checker again. It’s now coming up saying it’s connected to cab 28 and by the looks of the results any form of internet is basically non existent. Here is a screenshot
What could the reason for this be? Does it suggest that the results on this number through this checker are not making any sense? Last week said connected direct to the exchange and this week saying connected to cab 28. Can either of you tell me where that cab is?
or could it be that the previous occupier took her number with her hence it now says it’s connected to cab 28? I can check with her although we only completed yesterday so could it have updated as soon as today?
I also spoke to my neighbor today. It’s a semi detached house. She confirmed 100% that she has fibre.
I guess in reality I just need to be patient and wait until I have control of the line but just wondered if the different DSL result gave you guys any more thoughts on the issue? My hope is it’s proof that the  results for some reason on this line are unrealisable but maybe it’s as simple as she has moved the number with her. Is cab 28 FTTC enabled? I know where she has moved to and it’s still right in the city centre so those results look dreadful in terms of speed.
thanks
Nick
Message 40 of 57
The only logical conclusion is that the previous owner took their number with them and that is the result for the new property, although it does seem rather quick. Definitely something odd with the number.
Cab 28 is here
