Message 1 of 6
BT superfast firbe 1 download speeds stuck at a max of 35.
looking for help with my download speeds being capped at 35down, any help appreciated.
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: BT superfast firbe 1 download speeds stuck at a max of 35.
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
run btspeedtester and post results  must be done with ethernet connection not wireless
https://www.speedtest.btwholesale.com/
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 6
Thank you for the response.
Stats:
Product code:Smart Hub 2
Serial number:+091298+1847013147
Firmware version:v0.17.01.12312-BT
Firmware updated:Tue Jun 23 17:52:56 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,11 Hours35 Mins22 Secs
Data rate:17 Mbps / 39.999 Mbps
Maximum data rate:19.399 Mbps / 65.816 Mbps
Noise margin:7.1 / 13.0
Line attenuation:8.5 / 17.3
Signal attenuation:8.5 / 23.4
Broadband checker+BT speed results
Message 4 of 6
your connection time is only 11hrs is that due to hub dropping connection or manual reset?
any noise on quiet line test?
have you been having problems with hub dropping internet connection? often? or have you alos been resetting hub to see if you can improve connection speed
I think you are now in banded profile due to line instability and you now need to get a stable connection before you will see any improvement in connection speed and therefore download speed
Message 5 of 6
I have reset router quite a few times, this is a usual thing since our WiFi would randomly drop or we would get low speeds, so naturally i reset the router a few times but nothing changed.
We dont use the landline phone so i cannot test the quiet line test.
How can i get out of a banded profile?
Message 6 of 6
Hi @Harv04,
Thanks for letting me know the engineer was able to get this sorted for you.
All the best
David
