Message 1 of 7
BT youview box locked up
Hi, my by youview box is locked up. Whenever I reset via the on/off switch it goes to the waking up screen and just freezes unable to do anything. There is a solid blue light on LHS when this happens. Thanks
6 REPLIES 6
Message 2 of 7
Re: BT youview box locked up
If it's just cycling through the waking up sequence without actually going any further it's more than likely a harddrive failure. As long as you have an active BT TV subscription, BT will replace it for you.
Message 3 of 7
Thanks, do you have a number I can contact BT about this?
Message 4 of 7
0800 800150
Message 5 of 7
Hi @russ21345  and welcome back.
Sorry you're having problems with the STB. I reckon @NigelB72 is correct. Your best bet would be to give us a call and get it replaced as it sounds like the hard drive is kapput.
Cheers
David
Message 6 of 7
Rang BT today and a new box will be delivered tomorrow. Not an uncommon issue I am told.
Message 7 of 7
@russ21345 it's not especially on the Humax HD boxes
